Roller vs. cultipacker
Matt Page
12-01-2005 10:40:00
Was wondering what the differences were in function of these. I'm trying to broadcast plant rye, oats and peas. Have a plow, disk, and am looking at a spike tooth harrow. after that would I need rollers or cultipackers? Not familiar with what real farmers use, I've just always made do and am now trying to get equipment together. Thanks, Matt.
paul
12-01-2005 20:26:19
 Re: Roller vs. cultipacker in reply to Matt Page, 12-01-2005 10:40:00
The spike tooth harrow is all you will _need_.
The roller would push rocks into the ground, if you planed on baling hay, harvesting real close. I live in very rocky area, and only reciently have seen any rollers.
The packer is better suited to firming up the seedbed, as it flexes & flows a tiny bit - while also pushing rocks down.
But, you don't need either one. The crops you list will do fine with a 1/2 or so set spike tooth harrow.
--->Paul
snappie
12-01-2005 14:11:38
you will want a cultipacker. a cultipacker will evenly compact the seed to the soil, across the whole width of the cultipacker. with a roller, you would only touch the high spots and bounce over the stones.
snappie
12-01-2005 14:09:24
