tilt pin on blade
kurt keeler
11-30-2005 14:02:53
I can't get my tilt pin out on my Rhino blade,,,, any suggestions/tricks?
RickB
12-03-2005 14:25:19
 Re: tilt pin on blade in reply to kurt keeler, 11-30-2005 14:02:53
Take the clip out of the other end of the pin.
paul
12-01-2005 09:16:51
Not familiar with any specific brand..... What appears to be the problem?
Rusty? Use the blade as is, sometimes knocks the rust loose.
Bent pin? Will need to get progressively rough with it, up to cutting pin out with torch. Need a new pin.
Bent bracket? Again, need to get rougher with it, get things bent back in place.
Is the pin grooved, worn, or the bracket also worn? Kinda locks things in place with ridges in the wrong places. Bigger hammer, replace the worn parts....
Not sure what else can be, a pin in a 3pt blade is pretty simple.....
--->Paul
steveormary
11-30-2005 16:40:13
Bigger hammer? remove any stress that may be on it.
steveormary
steveormary
11-30-2005 16:39:19
Bigger hammer? remove any stress that may be on it. steveormary
wh
11-30-2005 14:49:54
trade for another blade????
