IH Two Disk Plow for a Farmall A
MACE
11-29-2005 09:04:20
Hello,
I just got my hands on an IH two disk plow. The disks are about 24 inches across and it has a steel wheel in the back with three weights inside. The wheel is steerable via a rod that goes to the front of the tractor. At the end of the rod is a 90 degree bend. Where would this rod connect to on my Farmall A? And what plow do I have. I can send pictures if needed. There is a picture of this plow being used in a book titled Farmall Letter Series Tractors. I believe the author is Guy Fay.
Thanks,
MACE
MACE
12-03-2005 10:56:22
 Re: IH Two Disk Plow for a Farmall A in reply to MACE, 11-29-2005 09:04:20
Here are all of the pictures
Link
MACE
12-03-2005 10:54:38
Link
MACE
12-03-2005 09:49:55
third party image
Ok,
Here are some pictures of the disk plow I have. I still need the attachement bracket that mounts to the bull gear housing. I may have found a steering rod.
Thank,
MACE
MACE
12-03-2005 09:52:16
 Re: IH Two Disk Plow for a Farmall A in reply to MACE, 12-03-2005 09:49:55
third party image
Disk Plow Picture
MACE
12-03-2005 09:53:47
 Re: IH Two Disk Plow for a Farmall A in reply to MACE, 12-03-2005 09:52:16
Still trying to figure out how to post pictures.
MACE
wh
11-30-2005 06:40:52
the bracket you need is a piece of 1/2 x 2 1/2 flat stock about 10 inches long. it has a hole drilled in one end to fit over the top of the spindle and a hole in other end to fit the steering rod. on the spindle end it has a turned down piece with a u bolt that clamps it to the spindle. sold the one i had with the plow last spring. if you can get a pic of one it should be no problem to build one.
Jimmy king
11-30-2005 01:27:46
You will need an arm that goes on the top of the spindle to hook the steering rod in, if I remember it clamps on it. Does it have a manual lever for the lift or does it have a rod to hook to touch control hyd"s.
MACE
11-30-2005 03:42:44
 Re: IH Two Disk Plow for a Farmall A in reply to Jimmy king, 11-30-2005 01:27:46
Jimmy,
It has the handle to lift the plow. It is not for hydraulics. I bet I have a hard time finding one of those rods.
Thanks,
MACE
Jimmy King
11-30-2005 08:03:36
 Re: IH Two Disk Plow for a Farmall A in reply to MACE, 11-30-2005 03:42:44
I don't know if the manual lift is the same number as the hyd or not. The hyd plow was for the Super A and was a A151. The A151 you take the draw bar off and a bracket bolts to the front side of the bull gear housing on each side, and the plow mounts there. There are some photos in the Implement Photos of a A151. As wh said in his post you could build a guide arm, his description is very good. Also does the plow have the scrapers on it they are very importion on adj. how the dirt is thrown. Jim
MACE
11-30-2005 15:09:02
 Re: IH Two Disk Plow for a Farmall A in reply to Jimmy King, 11-30-2005 08:03:36
Yes the plow has a scaper on the front disk. The rear disk is missing the scraper. I should be able pattern one from the front scraper. It looks pretty simple to construct. I think I may have found the arm that I need to steer the plow with. I will post some pictures here when I get enough daylight to take a good picture. The disks are in really good shape.
Thanks for the help so far,
MACE
MACE
11-30-2005 15:08:21
MACE
williamf
11-29-2005 15:07:56
I won't know about the plow, but if you can send pictures you can post them here. Click on "Help Identify" in the Galleries box at the left of this page, then find "Add Your Photo" and click on it. Follow the instructions and once your picture is up you can come back to this forum and tell people where to look. You can also make it show up here, but for now my fingers are tired.
Good Luck, Wm
PS I had an IH 2-disc plow behind a 350D many years ago. So long that I couldn't swear whether it was a pull type or Fasthitch.
