NH 256 Rolabar rake
Kent in NB
11-28-2005 05:39:13
After 2 years oflooking for a reasonably priced rake, I finally got one at auction this wkd. $500.00 and I supply the paint and new parts! Serial # is in the 116,000 range and am curious as to what side of 1970's this might be. Also,would someone know the right size traction tire(ribbed) to put on. Has car tires now,and they need to be changed for use in baleage. Has spring tines on it now, but should we spend extra and put rubber mounted tines on. At $7-8.00 each, this will get pricey. Thanks in advance, Kent in NB.
shovelman
11-29-2005 05:08:10
 Re: NH 256 Rolabar rake in reply to Kent in NB, 11-28-2005 05:39:13
Kent,
I use a 56 and 256 with spring tines with no problems. If memory serves, spring tines from CNH run about $1 each, rubber are closer to $5. When changing the spring tines, I use hardened (grade 5) carriage bolts with the special NH washer. The softer (grade 2) carriage bolts you find at the hardware store will sometimes break.
Miller Tire has 5.00-15 traction implement tires you need. Their site is: www.millertire.com
If the gearbox is leaking gear oil (a common problem) it is OK to use grease. Pull the cover, clean out the old oil and add 2 tubes of grease before replacing the cover. Be sure to check the bearings, gears, etc. as well.
Good luck,
Scott
Blue guy
11-29-2005 14:28:15
 Re: NH 256 Rolabar rake in reply to shovelman, 11-29-2005 05:08:10
That's good advice shovelman. I prefer the spring teeth also. CNH makes a kit for the spring teeth when swapping from the rubber teeth. It consists of the bolts and the metal fasteners. When I had my gearbox apart I drilled and tapped a hole for a grease fitting between the two hub bearings. I pumped grease until it was full, then installed the cover. Now I just give a couple of shots when I grease the other fittings.
Kent in NB
11-29-2005 05:44:41
Hi Scott. I just got prices on parts this a.m.. Tines are $1.51 for spring type and $6.19 for rubber. A new rim is $ 138.00!!! This is in CDN funds, but even so.... . Goodyear is supposed to call me back on tires,maybe. I see we have a Miller tire depot in the province so will check them out. Thanks for the service info, appreciate it. Seasons Greetings, Kent.
Shovelman
11-30-2005 05:16:16
 Re: NH 256 Rolabar rake in reply to Kent in NB, 11-29-2005 05:44:41
Kent,
Miller Tire should have the rim as well, for a lot less $$$. If you plan to get one aftermarket, check the offset and bolt circle to insure a proper match.
Another thought: the earlier NH balers (270 etc) used the same rim on the RH side. Maybe you could find a used one off an old baler.
I have had Miller ship large tires to me via truck and the price wasn't bad, but if you have to pay brokerage to get it across the border, it may be cheaper to get them locally.
Good luck,
Scott
Kent in NB
11-28-2005 16:48:21
OOPS! That serial # should read in the 161,000 range.
55 50
11-28-2005 15:23:33
According to the book "A Century of Ford and New Holland" by Norm Swinford, these 256 rakes were introduced in 1967.
BobMo
11-28-2005 06:00:03
Kent, I've had both rubber mounted tines and spring mounted and have found that the spring tines are far superior to the rubber mounted ones. I don't know about there but here the rubber mounted are about the same price as the springs. (slightly higher). Price is $1.25-1.50 ea. but if you want to pay $7.00 for them I'll buy them and ship them to you freight included. If you don't want or can't change out the tires right away add a little weight to the back of the rack. Good luck..... .
src
11-28-2005 05:58:33
That sounds like a good one. New Holland makes a great rake. I've got 2 #55's, older but still work like new. I would stay with the spring teeth. They are cheaper and I think they last longer. Mine have the rubber-mounted type, and
although they do work good, we have to replace some every year due to dry rot. If you do go with the rubber type, buy the good brand name ones. They last a lot longer than the cheaper imported brands.
hay
11-28-2005 05:46:31
5.00-15 tire. why change to rubber mount tines? i been using my rake with spring tines for many years and no problems.
Luke S
11-28-2005 06:07:54
 Re: NH 256 Rolabar rake in reply to hay, 11-28-2005 05:46:31
Great rake, I bought a real good one last year with dolly wheels for $1,250. My uncle said if I keep er sheded and take care of it it should last me a lifetime.
