replacing a gearbox on a bush hog
dale buxton
11-25-2005 18:37:08
I purchased a 7 foot AC bush hog that is minus the gear box. Thought that it would be easy to find a replacement gear box but I keep running into dead ends. The bush hog is in excellent shape other than the lack of the gear box. Does anyone know of where to find one or if I could use another gear box from another brand.
Rod in Smiths Falls, ON,
11-26-2005 15:19:14
 Re: replacing a gearbox on a bush hog in reply to dale buxton, 11-25-2005 18:37:08
Apparently the early gearboxes for rotary cutters were built in Italy. That meant a metric thread on the main shaft, I discovered last summer.
Fern(Mi)
11-26-2005 05:24:19
May I suggest a "Manufacyures Supply Co." SIL wore the gears out in his. Took it to Manufacture supply and while they could supply him with the gears, a whole new gear box was less money. If this appeals to you I can checkk his gearbox out for name and numbers and get back to you. He"s about four miles away. Or you could check a neighbor"s for a name and number if for nothing else specs and comparason.
Fernan
BobMo
11-25-2005 18:56:33
Dale take the information you have on the unit to your local Agco dealer and he can fix you up. Oh, take your check book to the tab will be about 1200 + or -. Good luck
