Plow hook-up question
Daniel H.
11-24-2005 10:27:59
Hi,
I have a Ferguson TO-35 tractor and a Dearborn 2 bottom 14" plow. When hooking the plow to the three point hitch should I use the stay bars that run from the end of the three point arms to a bracket under the fender mounts on the axle? Or, should the hitch be free to move left to right? Thanks, Daniel
paul
11-24-2005 21:38:02
 Re: Plow hook-up question in reply to Daniel H., 11-24-2005 10:27:59
You shouldn't need the anti-sway bars. A properly adjusted plow should pull straight & not need the bars.
You will need to adjust the plow in all 3 directions, so that it basically pulls nice & straight. Can take some tinkering to get it all right.
--->Paul
jhill
11-24-2005 12:02:08
Don't use straps plow should be free to move around. If it is adjusted correctly it will self center.
