855 newholland round baler
Hurst
11-20-2005 11:18:05
What size bales does this baler make? I know it is variable chamber, so I am assuming it can make just about any height bale. Are they good, dense bales? I was just thinking about one for baling bluegrass for horse bedding, maybe about 500 bales a year at most. Right now we have an M&W 4500 (4x5 fixed chamber). It is alright, but the bales are not that tight and you can't make shorter bales, which limits how high we can stack them in a shed. Is there anything I should know about the 855? Is $3500 a good deal for one that looks to be in good shape? Also, will this baler bale silage type material (such as loose bales of wet horse manuar? Not guarenteeing doing this since it has done its toll on our M&W. I just like the chain drives, they seem they would be a little more reliable than belts and stronger and also, they are less expensive and I don't need to worry about leaf loss either. Also, Will a 763 bobcat handle one of these baler's bales? The 763 can safely lift about 1500lbs I think. Thanks.
Hurst
old
11-20-2005 18:42:35
 Re: 855 newholland round baler in reply to Hurst, 11-20-2005 11:18:05
If the 855 is any thing like the 850 that bobcat will not move them with out doing a nose dive. As far as to the price I know a place that has a couple of the 850s for $500 each. My 850 puts out bales around 2000-2500lbs.
jd9295
11-23-2005 10:55:59
 Re: 855 newholland round baler in reply to old, 11-20-2005 18:42:35
what part of the country are you in OLD? I would be interested in the 850's for $500 You cant buy a junk one here for that
dp in nd
12-10-2005 19:07:51
 Re: 855 newholland round baler in reply to jd9295, 11-23-2005 10:55:59
jd9295 where are at, I am in ND
dp in nd
12-10-2005 19:03:58
old
11-23-2005 11:35:03
I'm in Missouri, the place that has them is in Versailles MO.
