What will this fit.
Jim Lockhart
11-14-2005 19:37:38
May have found a model 2-MH IH corn picker,will it fit an 1947 H farmall?Thanks
Itchy
11-17-2005 10:52:45
 Re: What will this fit. in reply to Jim Lockhart, 11-14-2005 19:37:38
I dont think IHC made mounting brackets for an H tractor. The IHC #24 picker was made for the H,SH,300 and so on.
DAJ
11-15-2005 08:03:33
We had a "H" break in half with the old smaller Picker.
Jerry Coulter
11-15-2005 07:40:46
My father-in-law harvested with one on his H for a number of years. I never noticed any overload. What a job every fall mounting that beast! Eventually, I ate up the tranny on that tractor while plowing.
Leroy
11-15-2005 15:56:06
 Re: What will this fit. in reply to Jerry Coulter, 11-15-2005 07:40:46
Are you sure it was that model and not the picker made just for the H?
Punchie
11-15-2005 05:41:50
HI Too heavy ? Maybe need to not say anything, but I thinking about the old H we have has the same tires as a M and just about 35 HP. ( super H with a 300 Head, would look just like a Normal junk H to any else. ) Unless the frame would not handle it. I would say it would depend no the tractor. H can be from the low 20's in HP to higher than 40-45 with out alot of extra work. If you go nuts alot more than that but you would not use it in the field.
Have a Good One !! Teddy
Josh H
11-15-2005 06:53:28
 Re: What will this fit. in reply to Punchie, 11-15-2005 05:41:50
The axles on an H will break, and even a fair amount of M's have broken rear axles under the weight of a mounted picker.
Leroy
11-15-2005 05:29:01
Way too heavy for that small of a tractorm minum of an M
