dearborn grass aerator?
jim vandendries
11-13-2005 08:52:43
Have a dearborn implement-model 13-09 serial 11648. Has the same appearing frame as my cutiavtor but has about 30 spring teeth aith 12 inch rods on the ends. I have been using it to pull across the lawn to get the dead grass and leaves out in the fall. The problem is some of the sping teeth are missing and do not know where I can locate replacements. Does anyone have a line on used parts for Dearborn equipment? I ahve searched the internet but have yet to come up witha source or anywhere I can get a line on Dearborn equipment using the model and serial numbers.
Tim(nj)
11-13-2005 15:14:11
 Re: dearborn grass aerator? in reply to jim vandendries, 11-13-2005 08:52:43
That sounds like a finger weeder. Agri-Supply sells replacement finger weeder teeth, but I don"t know if they"ll work for the Dearborn. Have you taken that model number to a New Holland dealer? It"s a longshot but maybe new teeth are still available OEM.
