One row corn planters? Food plot Planter?
midalake
11-13-2005 05:50:16
I have been looking for a one row corn planter for doing food plots. Has anyone used the Burch? Of a JD 25-B? I have two goals in mind with doing this.
I would like the planter to be reliable with seed drop, also fairly easy to use.
Thanks....
Leroy
11-15-2005 05:43:03
 Re: One row corn planters? Food plot Planter? in reply to midalake, 11-13-2005 05:50:16
For what you want just get a older cheap 40" setup planter and just double plant to get 20" rows and to do that just plant as normal then just start again as you did the first time but use one row as guide for center of tractor instead of marker and you will have the 20" rows and for food plot don't worry about accuracy of seed drop, it will be good enough
riverbend
11-13-2005 19:23:39
Any plate type planter will be fairly reliable as long as it is not completely junk. Why not use a two row ? It will cut the number of passes that you need to make in half.
Isn't the 25-B a vegetable planter ?
midalake
11-14-2005 14:10:48
 Re: One row corn planters? Food plot Planter? HELP in reply to riverbend, 11-13-2005 19:23:39
These are the things I just do not know.....I would like some input....some of the older planters plant on 30" rows I would like to go with 24" HELP!!!! Let me know what I need to be looking at????
Thanks Dave
paul
11-14-2005 16:20:39
 Re: One row corn planters? Food plot Planter? HELP in reply to midalake, 11-14-2005 14:10:48
Planter, cultivator, & corn head need to all match.
Common row spacing was 42, 40, 38 inch because that is how wide a horse is. 36 got some notice too.
30 inch turns out to be far better for yield when you don't have to worry about fitting a horse in the row. And it works well with different wheel spacings on the tractors & implements, nice easy number, you can straddle 2, 3, or 4 rows easily.
In beet country 22 inch is popular, it's the right size for beets & beet equipment. Turns out it worked well for corn too.
We kinda figured out narrower rows are better, so 20 inch and 15 inch is the 'new' thing starting to show up. Many older planters cannot be spaced that close together, something will hit & not fit.
You will be going it alone if you want 24 inch, that never was a common row spacing. Many types of planters can be slid together or apart for different row spacings, but I'd stick with 30 inch, that's what is common. I understand you won't be harvesting it, so not a big deal I suppose.
--->Paul
midalake
11-16-2005 06:08:52
 Re: One row corn planters? Food plot Planter? HELP in reply to paul, 11-14-2005 16:20:39
You are correct about not harvesting it. I plan to let it stand all winter then brush hog it and turn it in. What were some good old planters then?
Thanks
