Minneapolis-moline LA combine
Albert
08-26-2004 18:20:32
I was driving around today and seen a MM pull-type combine sitting in a welder company's parking lot and found it was a "LA" It is borderline restorable and has a auger feederhouse system. Has anyone ever heard of this machine? If so when was it built etc?
R R
09-26-2004 14:40:42
 Re: Minneapolis-moline LA combine in reply to Albert, 08-26-2004 18:20:32
Albert, Are you buying this MM combine? If not, could I have the info on it. Even if you did buy it, I'm curious as to what size and year it is?
Thanks, Ron
Albert
09-27-2004 12:54:17
 Re: Minneapolis-moline LA combine in reply to R R, 09-26-2004 14:40:42
I did not buy the combine because apon further inspection I noticed raccoons tore the insides to shreds. It was a combine designed for the Uni-harvester concept. The owner has a uni sitting on the same lot but is reluctant to sell it, even though it needs an engine overhaul. He also has the corn sheller attachment sitting in a field, but since he has no interest in selling the uni I didn't check out the corn sheller.
grandfield
10-24-2004 19:31:22
 Re: Minneapolis-moline LA combine in reply to Albert, 09-27-2004 12:54:17
I have a working LA on a 1953 Uni. Where are these machines located? I'm in NE Illinois. Thanks, John grandfieldfarm1@aol.com
