Out of production combine belts
Albert
08-03-2004 19:34:01
Are there any manufacturers out there who will custom make drive belts for combines that are unavaliable and out of production? If not how can you get those hard to find belts in usable condition? I'm sure this is a problem most older combine users have encountered.
jim
08-08-2004 22:02:37
 Re: Out of production combine belts in reply to Albert, 08-03-2004 19:34:01
It probably is a standard belt.(I'm assuming V). Remeasure its legnth and width. It probably stretched some. Most equipment is a little forgiving and you may be able to use the next size down or up. An inch longer is only 1/2 inch movement.
Jim@concordfarms
08-04-2004 08:38:50
I've worked as a machinist and also farmed most of my life. My theory about farm machinery is that manufacturers use industry standard items as much as possible to save money. They adapt their products to use off the shelf bearings and V belts as much as possible. So if it's a V belt you need, you'll probably find it at McMaster Carr or JDV without a problem.
ihkovas
08-03-2004 23:44:46
Albert, I don't know if they make custom belts,but I got a cyclinder drive v-belt for my McCormick 76 from this place. (www.jdv-belts.com)
Albert
08-05-2004 19:38:11
 Re: Out of production combine belts in reply to ihkovas, 08-03-2004 23:44:46
THANK YOU very much for the website it is the 1st place I have found that has a belt at all for my particular combine! EXCEPT the one I need haha go figure. Anywho thanks again great site
max adams
08-07-2004 18:49:12
 Re: Out of production combine belts in reply to Albert, 08-05-2004 19:38:11
Hey Albert, what belt are you looking for? i have a lot of extra belts that came with my 101. i guess this is what you are wanted these for?
e-mail me. max
paul
08-05-2004 00:46:11
This is the place to try, they have a heck of a selection of belts, and are crossed to ag equipment already.
--->Paul
Wayne
08-03-2004 21:11:48
I'm a heavy equipment mechanic by trade so I've never really messed with any combines to know what, if anything makes the belt so special. I do know from the years I spent doing industrial maintenance work in that there are places out there that can make just about any type of belt you need. Try Thomas Registers online site and do a search for belting suppliers/manufacturers. I did a search on there and it returned alot of different ones. Here's a link to that search page. If it doesn't work for some reason go to Thomasregister.com and simply do the search again. Good luck.
