Oliver 7300 final drive
ChrisL
07-26-2004 20:31:01
10 years ago we had 8 rows of corn left and the combine died - started it up but as soon you start to release the clutch it feels like it is in forward and reverse gears - we had to take the splied collars off out by the wheels so we could pull it into the trees wit h a tractor ---
I would like to see it run again - (the engine is the 318 Chrysler - still OK I think -
Is there any off chance anyone knows what that problem is and might it be easy to fix?
I think we checked all the shifting mechanisms, linkages and cables and it doesn't seem to be that....
paul
07-27-2004 19:49:48
 Re: Oliver 7300 final drive in reply to ChrisL, 07-26-2004 20:31:01
On my IHC tractor when it does that, the shifting collars get 2 selectors in gear at the same time. Sounds like you checked that? Would seem to be some blockage in the tranny. Can you still shift it? Does it drive when you put it in neutral? Can you spin the output shafts when in neutral? Could be a melted down bearing somewhere in the tranny. Lots of things I guess. But the final drives are ok, and the input to the tranny is good with the clutch in, so you are pretty much looking at the tranny....
--->Paul
