New Idea 323 Corn Picker
Rich
03-22-2004 13:12:39
Does anyone know how far the spacing has to be between rows for the 323 to work properly? Also, since we just purchased a real nice used one, and have never used one before, what's the PTO speed and tractor speed?
Thanks for any help you can provide and have a nice day!
JMS/MN
03-22-2004 13:18:02
 Re: New Idea 323 Corn Picker in reply to Rich, 03-22-2004 13:12:39
Correct speed for a pto operated harvester is either 540 or 1000 rpm. 540 speed machine will have 14 spline coupler, 1000rpm machine will have a 21 spline coupler. Tractor speed depends on how good a crop you are harvesting, probably 1 1/2- 3mph. Row spacing on your planter and picker need to match.
Toocold
03-22-2004 16:34:08
 Re: Re: New Idea 323 Corn Picker in reply to JMS/MN, 03-22-2004 13:18:02
I pick 30" rows with mine.
tim[in]
03-22-2004 14:08:37
the 323 is a 1 row you can run it at speeds of up to 540 rpm .most old timers said to run the older style pickers with brass bearings no faster than a fast walk. however the 323 is designed with modern bearings and probably can be run a little faster. ground and crop conditions like stalk breakage will deside this. the one rows can take as narrow a row as possible without breaking the stalks in the next to be harvested rows or knocking the ears off. my ac dealer told me that a one row can pick 2/3 of what a two row will. it seems that it should be twice as much but then that too probably depended upon conditions. as always shut it off to lube or unplug corn or weeds.
