McCormic No 15 chopper
darren
02-07-2004 18:13:34
I'm 19 years old. my brother and i are looking to get into farming. we're planning to buy some beef animals this spring and would like to put up two bunk silo's one of corn silage and one of hay silage. I've got an old international 15 with a pick up head and a corn head, i've had good luck with corn but haven't had a chance to try it on hay. I'll probably run it with an International 560d. i was wondering if it will do what i want or should i go buy a new holland 717? i don't want to fight this thing all summer
Tim(nj)
02-08-2004 14:55:29
 Re: McCormic No 15 chopper in reply to darren, 02-07-2004 18:13:34
A 717 won't be much better. If you do upgrade, go with a chopper that has a recutter screen, not the cut-and-throw style, which is what the 717 is. Most silos around here are uprights. Can you make bunker silage out of hay? I've only ever seen it done with corn.
David N.
02-09-2004 19:03:34
 Re: Re: McCormic No 15 chopper in reply to Tim(nj), 02-08-2004 14:55:29
You should do just fine with the 15. We used one for years for chopping corn, haylage, sudax, and used it for years for daily green chopping until we got a JD 16-A for that. Ran it at different times with an H, acouple of M's, Super M and a Super W-6. I would be using it yet but the flex coupling on the gear box is broken and they are hard to find and expensive if you do.
Darren
02-10-2004 11:08:19
 Re: Re: Re: McCormic No 15 chopper in reply to David N., 02-09-2004 19:03:34
hey David N. where are you at? im in north east Pa if you need parts -- name your price, i know a guy that has a couple of 15's sitting that haven't been used in a while i'm sure i can get you parts if you want them
David Nemeth
02-10-2004 16:48:39
 Re: Re: Re: Re: McCormic No 15 chopper in reply to Darren , 02-10-2004 11:08:19
To Darren, I am in Campbell Hall, NY. This is in Orange County in SE NY state. I would appreciiate it if you could help me get the parts I need. Please give me a call sometime at 845-427-2867 or 845-344-3933 eves. Thanks.
