Wisconsin V-4 stuck valve
ANDY
10-30-2000 11:00:29
I have a Versatile 103 swather with a stuck exhaust valve. Is there any body out there that has a suggestion on a fix that doesn't involve tearing into it. I have been soaking it with various "Knock'er loose" remedies and have loosened all but one stuborn one. Thank you!
larry
10-30-2000 17:04:38
 Re: Wisconsin V-4 stuck valve in reply to ANDY, 10-30-2000 11:00:29
My favorite is remove the sparkplug ,then squirt valve with penatrateing oil, then push valve down with an allen wrench. Repete as needed.
ErnieD
11-02-2000 16:28:54
 Re: Re: Wisconsin V-4 stuck valve in reply to larry, 10-30-2000 17:04:38
Good suggestion. I might add that if the valve doesn't want to move to turn the flywheel 180 degrees to get it off the cam.
