John Deere 3300 engines?
TB SCOTT
10-13-2000 04:56:50
What engines were available for the John Deere 3300 combine? thanks :)
Doug in IL
10-13-2000 19:05:02
 Re: John Deere 3300 engines? in reply to TB SCOTT, 10-13-2000 04:56:50
The gas engine was 202 cu in. 64 horsepower. The diesel engine was 219 cu. in. Same horsepower rating.These engines were also used in the JD utility tractors of that era. I think they may have had a horsepower boost to 70 horse some time during the manufacturing run for the 3300.
Fed barnse
10-19-2000 17:13:03
 Re: Re: John Deere 3300 engines? in reply to Doug in IL, 10-13-2000 19:05:02
I had trouble with one of thoses 202 gas engines so I took a old 471 gm diesle and hook on a cluth pack to power the combine. if you need any more info on how I installed it you will find me and my combine in the grave yard
Tim(nj)
10-13-2000 18:55:38
The 3300 gas used a 292 Chevy straight 6, if I'm not mistaken. Not sure about the diesel. Might have been a 329 Deere. Would have been same engine as in 4030 diesel tractor. This engine is very susceptible to cylinder wall cavitation. Neighbor had a 4030, overhauled twice in 3000 hours because of cavitation, then put coolant conditioner in, been ok since. If you look at a diesel 3300 or a 4400, for that matter, check the radiator for oil floating in it. If you find oil in there, it can mean that cavitation has happened.
Doug in IL
10-13-2000 19:14:32
 Re: Re: John Deere 3300 engines? in reply to Tim(nj), 10-13-2000 18:55:38
The 4400 used the 292 Chevrolet gas engine and the 329 JD diesel. The 329 JD engine is also used in the 4030 tractor. I have owned 2 6600's with the 329 and still own a 4030. Never had any cavitation problems with any of them. But, as in most wet sleeve engines, you must keep good, clean, fresh antifreeze in them and coolant conditioner also.
Tim(nj)
10-14-2000 19:53:37
 Re: Re: Re: John Deere 3300 engines? in reply to Doug in IL, 10-13-2000 19:14:32
I know of in this area 2 4400s, 1 6600, and 2 4030s, as well as a 4420, that all had engines with cavitation problems.
