No Fool Like An Old Fool
Allan In NE
04-25-2008 10:51:33
Well fer DUH!
Feel dumber than a 55-year-old corner post.
The key to removing the mainshaft outer pulley on an early F2 Hydro is to reach up and pull it off..... ..... ..... ..... ..... ..... ..... ..... ..... ..(by hand). Wasn't even pressed on.
Taper lock is in behind the goofy thing on the inside pulley. :>(
Allan
third party image
Ben in KS
04-26-2008 09:30:35
 Re: No Fool Like An Old Fool in reply to Allan In NE, 04-25-2008 10:51:33
Allan, You definitely need some Kroil in there! Ben
Allan In NE
04-26-2008 10:10:05
 Re: No Fool Like An Old Fool in reply to Ben in KS, 04-26-2008 09:30:35
Yeah,
I let it cool back down and then soaked it overnight with penetrating oil.
She's comin' off of there; it just doesn't know it yet! :>)
Allan
JoshuaGA
04-25-2008 19:28:53
 Re: No Fool Like An Old Fool in reply to cadet trooper, 04-25-2008 10:51:33
Allan In NE said: (quoted from post at 09:51:43 04/26/08) I'm payin' for it now tho. Oh my goodness is that rascal stuck!
Gotta go get me some grade 8 push bolts in the morning. The sow is flat "grown" on there. :>(
Allan
Cant be any worse than a PTO shaft I have. Scrapping our feed mill, going to save the shaft. Beat it, no go. Skid steer out there, lets try that. Would you believe the skid steer couldn't even pull it off. It is "rust welded" gooooo ood.
JoshuaGA
cadet trooper
04-25-2008 17:08:22
Wellll, I ain't goin there Allen you're preachin to the choir!!!!
Allan In NE
04-25-2008 17:51:43
 Re: No Fool Like An Old Fool in reply to cadet trooper, 04-25-2008 17:08:22
Allan
third party image
John_PA
04-25-2008 12:00:19
Looks like you got some slobber on the pulley from beating your head against it.
When I can't figure out a problem, I go find a 4 year old. They usually solved these complicated issues in about 10 seconds. :D
Good luck with the repair!
John
MIKE FRENCH
04-25-2008 11:03:01
Dont you hate when that happens, problem is your not suppose to tell on yourself, Mike
Allan In NE
04-25-2008 11:07:34
 Re: No Fool Like An Old Fool in reply to MIKE FRENCH, 04-25-2008 11:03:01
Sometimes (more often than not) I'm my own worst enemy. :>(
However, me thinks I do see a tug coming with the puller when I get down to that bearing boss in behind that big pulley.
Allan
