What Are Junkyards Paying For Old Combines In Your Area?
1206SWMO
03-08-2008 09:44:41
My local yard is paying $80 per ton for complete combines and they dock pretty good for the tires.They dont like complete combines as they wont fit in the crusher without being cut in half.Cut down they pay $150 per ton here.
A junker that I know pretty good has quit buying old combines because he says it costs him too much to cut them apart.If he finds a good one I get first chance on it.I got a 35 Massey from him that he saved out of a junkyard.
I have too many people price old combines to me at $200 a ton because thats what they heard that they can get at a junkyard.
Farmers son
03-09-2008 15:34:02
 Re: What Are Junkyards Paying For Old Combines In Your Area? in reply to 1206SWMO, 03-08-2008 09:44:41
at loda illinois scrapyard they are giving 100.00 a ton for whole machine or 200.00 a ton cut up. my old man and me just scrapped one of our old 715,s. that was totally empty of parts. probably made 5 or 6 hundred after expenses of gas to haul it and oxy/acetlyn fill ups.
michiganmilkman
03-08-2008 12:52:08
the scrap yard around here wont take combines no more. there is a early New Holland 9xx there now and they dont want to cut it apart. but i took some old rusted culverts in the other day and got 210 dollars a ton.
John_PA
03-08-2008 12:52:17
tires are $15 a piece for fronts, rear are $2 a piece.
The gas tank has to be removed from the machine.
They prefer that cab glass to smashed out or removed, same with mirrors.
It takes approximately 30 seconds for them to remove the cab, engine, and separator body from the main frame and transmission. The engine and main chassis goes into a mixed steel pile, and the separator, cab, bin, and heads go into the tin pile. They do it in less than 3 minutes with a lebierr "scrap master" with a clam bucket. They have a steel I-beam that they lift up with the clam bucket, and slam it down a few times on the combine. They can turn a Gleaner G into a tin can that is 4 feet tall. Some of their scrap piles are 80-90 feet high. It's wild to see an Allis Chalmers WD flipped upside down and piled 60 feet up in an unrecognizable pile of junk. (I've seen quite a few like that) Even saw a John Deere A on steel wheels which looked like it was salvagable, crushed to bits. That dumb dumb could have sold the junk JD in the classifieds for $2500 as a "Restoration project"
Of course, I take them to Neville Island, PA, which is an island on the ohio river, about 5 miles downstream from Pittsburgh, PA. They pay top dollar, as they process and sell directly to mills.
at last check, Iron is up to $11 / hundred lb. Tin is $9.50 / hundred lb. mixed steel/iron is $7.50 / hundred lb.
that is for unprepared metal. I don't know what prepared metal is selling fr, but I took some prepared aluminum in, and I got $76.00 / hundred lb.
So the prices are very high right now.
The expensive part is hauling the combines down there. You can't use a tow dolly. The ohio river valley is quite a drop in elevation from here. Not to mention, traffic is a nightmare, and not accustomed to "rural" travel.
