Oliver 525 pics
71ford100
03-07-2008 20:19:14
A couple pics of an Oliver 525 that was given to me several years ago that I haven't figured out how to get yet.
third party image
third party image
kirk in ks
03-08-2008 05:38:15
 Re: Oliver 525 pics in reply to 71ford100, 03-07-2008 20:19:14
Hi Blaine,,
you suppose i could do that with that Minnie too ???
I mean tow it back to here in Alton with back roads,
I mean i dont see anything wrong with it , I mean It's be alot simpler than getting a trailer to load it on and then hoping no one sees you, haha
1206SWMO
03-08-2008 17:09:52
 Re: Oliver 525 pics in reply to kirk in ks, 03-08-2008 05:38:15
Kirk, I wouldnt want to pull a S MM combine 700 miles home.It would take you 4 long days.200 miles is about as far as I would want to pull a combine using a trailer as a dolly.
The way they are built you would have to run thru the transmission.They dont have final drives where you can uncouple the axles.
kirk in ks,
03-09-2008 03:52:26
 Re: Oliver 525 pics in reply to 1206SWMO, 03-08-2008 17:09:52
Hi Blaine,
Ohh Ok , well,,, mo big thing then, I guess ill just load er on a trailer and bring er home,
Blaine where was that S MM in that yard with the junk cars around it???
Was it in Ks,or Mo or where was it? It look's neat, and salvageable.
1206SWMO
03-07-2008 22:52:50
Lance, Take a car trailer and use it as a dolly.Put the rear end up on the trailer and pull it home backwards at 20-30 mph using the back roads.You will need some good tires on the combine and be sure and pull the axle couplers.The same goes for the 4296 MM.
