Some MM Combine Pictures From Howard H
1206SWMO
03-07-2008 08:27:00
third party image
third party image
Howard H emailed me some pictures from the Texas-OK Panhandle area of what appears to be a 2890 MM combine.If its 28" wide its a 2890.If its 34" wide its a 3496.I'll let Howard tell you more.
How many on here own a 2890 MM?I know that combinechris does.
My local MM dealer Bell Tractor sold two new 2890's.I watched one of these sell for $75 last summer.It was missing the header and was in sad shape except for the engine.
71ford100
03-07-2008 22:47:43
 Re: Some MM Combine Pictures From Howard H in reply to 1206SWMO, 03-07-2008 08:27:00
If its a V-8 its a 318 Chrysler.
Howard H.
03-07-2008 15:30:45
Yep - pretty good looking old combine, but haven't found the header, yet...
I thought it was funny - you can see the bearing in the end of the unloading auger - it is a wood block that the shaft rotates in...
I remember the old wood block bearings on Dad's JD 105 straw walkers - worked fine, but wood bearings seem a little funny by todays standards...
This has a V-8 engine in it. I didn't know MM had ever heard of a V engine! ha...
HH
1206SWMO
03-07-2008 22:45:27
 Re: Some MM Combine Pictures From Howard H in reply to Howard H., 03-07-2008 15:30:45
Howard, If its a V-8 then its a 4296.It just didnt look 42" wide in the picture.
Fordfarmer
03-12-2008 09:50:55
 Re: Some MM Combine Pictures From Howard H in reply to 1206SWMO, 03-07-2008 22:45:27
I don't know about the MM's, but my 525 Oliver's owner's manual listed the 318 V8 as an option.
Howard H.
03-09-2008 10:20:47
Here is a pic of the engine - Moline yellow V-8... They must have set the engine on the line when building it and then bolted everything to it - as tight as it's tucked down in there!!
third party image
Howard
tbone4
04-05-2008 19:44:37
 Re: Some MM Combine Pictures From Howard H in reply to Howard H., 03-09-2008 10:20:47
We Have been trying to get ahold of a 4296 and this one looks pretty good. Please let me know if you are interested in discussing a deal on it.
Thanks
tbone
Paul Em
03-07-2008 12:45:12
Man that looks ALOT like our old White 7300 combine. One company buy the other out?
Fordfarmer
03-07-2008 14:18:04
 Re: Some MM Combine Pictures From Howard H in reply to Paul Em, 03-07-2008 12:45:12
I think the 2890 was the MM version of the 525 Oliver. Used to have a 525... worst thing about it was the Carter carb.
Jon Hagen
03-07-2008 13:00:23
Yep, the same combine sold in Oliver green,(they were Oliver combines) Moline gold, Cockshutt red, or later all painted red under the White Farm equipment name.
71ford100
03-07-2008 11:32:10
I had a 545 and a 2890 given to me by North Platte but really haven't figured out how to haul them due to weight. They both have platforms and corn heads. I also know where another 2890 is that I need to go look into.
