Need feedback on combine
Spike in WI
01-31-2008 17:30:38
Gentlemen,
I'm looking to buy a good used combine. I put an ad in the local shopper and got four responses. They are as follows: 6600 JD sidehill 4R wide cornhead -$4000 IH 815 4R wide cornhead and 13' grain - $3500 Gleaner F 4R narrow cornhead and 13' grain - $4000 New Holland TR 70 4R wide cornhead and grain - best offer
Can you guys give me some feedback on what to look for on these machines
Thanks
Mike
HeyPigFarmer
02-02-2008 10:29:34
 Re: Need feedback on combine in reply to Spike in WI, 01-31-2008 17:30:38
Spike
A combine is not something you want to spend 10 minutes looking at and say "this is the one" - get in them, drive them around, drive all of them, what are you out other than time and maybe a little fuel money. As far as the prices go a lot of that depends on the hours and condition of the machine. Two years ago when I bought our TR70, NH 972 16ft flex, and NH 974N6 I paid $6000 for the whole set up with around 4000hrs. But the engine ran good, and 3 years prior he replaced every bearing, belt and chain on the machine - compliments of GM, two years prior he put in new sieves and rasp bars. Dad then sold his 1976? 6600 with the 404 engine, 215flex, 643-N6 with 4800 hours for $5500
Just at a quick glance the price on the price on the Deere doesn't look bad, the IH may be a bit on the pricey side depending on what the head is on it, the Gleaner the price doesn't look bad either since it has both heads. But coming with heads can be a blessing and curse depending on what you need. Heads can get expensive depending on what you need, but you may be able to use the heads they come with as trading stock to get what you want. Plus prices vary a little bit by area also.
I guess look at them, then go to a website like tractor house, machine finder, us farmer, equipment locator and compare. Right now you have nothing but time.
HeyPigFarmer
02-01-2008 05:55:16
Every piece of used equipment is only as good as it's previous owners. Every combine is only as good as it's operator.
HeyPigFarmer
02-01-2008 05:53:12
Building on what the others have said, parts availability, dealer support, familiarity with the machine, making sure the heads match up with your equipment there are a few other pointers. A hydrostat combine is a whole world nicer than a gear machine, even though they have that variable speed the hydro is so much nicer to use it’s amazing. Overall make sure the bottom of the machine and grain tank aren’t rusted through, make sure the elevators don’t have holes worn in them. As always all belts and chains, axle pivots, spindle bearings and wheel bearings. Check to see if the machine has been welded on anywhere and why it’s been welded on. Check elevator chains especially, those get spendy in a hurry and make sure it has all it’s paddles on it. Feederhouse chains are also quite expensive. Look at the belly of the machine overall and look for places that chains have been attached to pull them out, it is possible to stretch a machine making it basically junk. Look at basic maintenance items, how much grease is spewing out of bearings, have the filters been changed recently that sort of thing. Look at the electrical, you can spend days fixing someone else’s mistakes. Look at tires, the JD and the NH use the same rim but no matter what 24.5 or 28L 26’s are expensive. But sometimes you can buy used ones on rim fairly cheap compared to new. Especially since all newer combines are going to 32’s 38’s and now 42’s.
Everyone else has good pointers now onto specific machine traits. We have had two of the machines listed, the others I have no comment.
The 6600 is not one of my favorite machines but if you need a side hill than I’d say go for it. When you look at it other than the above things if it has a straw chopper on it look at the rear section of the combine, the sheet metal tends to crack around there if the copper is out of balance and I have seen one fall off. Look at the sieves or chaffers, whatever you want to call them, on that era Deere machines they like to crack along the front and rear making it hard to adjust and just about useless because that leaves a direct track to dump grain and tailings directly below. Replacement frames start around $800. In front of the sieves, at the end of the auger bed make sure the fingers are all still there, if they aren’t grain dumps directly to the re-clean auger. Check the bearings on the walkers. Look through from the trap door on the top inside to see if the fish-backs have come loose beat the stuffing out of the inside of the machine. Look on top of the walkers toward the front of the machine, there should be a flap hanging down, if it’s not there it needs one otherwise the cylinder throws stuff straight out the back. There is a door above and below where the feederhouse meets the machine, look at the cylinder and the concaves make sure they aren’t broke. If your worried about rasp bars now’s the time to look too. Make sure the hydraulics work smooth. The hydraulic pumps are known to go out ona regular basis, which isn’t bad but the pump is mounted on the end of the direct shaft to the engine and is threaded on there. After years of rust they get stuck on, you use a torch to get them off, that ruins your core so a new pump will run ya over $1000 to change out. The other big thing to look at on a Deere from that era is the axles going to the outer drives. Look at the splines on them. These machines had a light frame, and if it had a large grain tank extension on it or if it was pulled out of the mud incorrectly the frames sprung, causing other bad things to happen and wear out but a tell tale sign is if the axle splines are worn. As far as motors go, the gas will really suck the fuel, the diesel needs more power but is reliable if it has the 404 they start hard the 359 German starts better.
Now onto the TR70. First off there were three choices of engines on the TR70. The 3208 Cat - which is the best choice, the 363 diesel Ford turbo industrial – which was underpowered to use the capacity of the machine but held up decent if not over worked, and the Ford 361 V8 Gas – stay the heck away from the gassers that thing would suck fuel like it was it’s job. Once again, each side of the machine there is a door you can take off to look at the cylinder part of the rotor, check the rasp bars, look at the concaves, see which concave it has in it (large wire, universal which has large wires with pipe covers over them, or small wire) Small wire ones shouldn’t be used in large grain, the large wire ones have spots to put small wires in to do small grains as do the universal ones. See if it comes with these extra wires. Look above and below the rotors, if it has been plugged hard the machine will bulge in these areas. Look at the front of the rotors to make sure rocks haven’t busted off the feeding ears. There is another inspection door below the rotor doors, take those off to look at the shaker table and make sure it isn’t rusted through. From there move toward the back look at the sieves, make sure they can be adjusted still. Crawl up on the sieves if you can and look up at the rotors for damage or damage to the rotor cages. Look at the discharge beater in the back, that usually is a give away of how many rocks it has eaten. Look under the discharge beater to see if it has the filler plates, if you don’t then when you do wheat it will poop straw on top of the sieves. If it has a straw chopper on it in order to dump the straw to bale it you don’t remove the straw chopper there is a door above it that swings, look at where this door attaches to the body, sometimes you get stress cracks around there. Look at the center axle pivot, that tends to wear out. Pull the inspection doors off the elbow on the unloading auger and check the gear boxes for slop, this can be done by hand. If you are feeling agile craw inside the grain tank, pull off the engine access door, from here pull off the rotor inspection/removal covers and check the slop in the gear boxes. Make sure the machine engages solidly, unlike a Deere the NH uses a clutch instead of a belt adjuster to engage the separator. While the separator is engaged the machine should be perfectly smooth, if not your rotors are out of balance, which is kind of a pain if you care, hard on bearings and coupler chains if you don’t. Look at the brake drums, if it’s a hydro you will hardly ever use the brakes but they tend to shear off at the shaft on these. One last thing to look at is fuel filler placement. If it sticks out toward the ladder over top of the tool box then it’s a late model, if it sticks out over the side into no mans land, it’s an early model.
Sorry for the long rambling message but that’s the base of it. When I look at a machine it takes me about 3 hours. Pisses off dealers but who cares about them, just hoping others can learn from my mistakes.
Spike in WI
02-01-2008 14:10:04
 Re: Need feedback on combine in reply to HeyPigFarmer, 02-01-2008 05:53:12
Hey pig farmer,
Thanks for the reply. It looks like it will take longer than I thought to look these over!! Do the prices posted look reasonable?? I think the F Gleaner is way overpriced. The sidehill feature on the 6600 would work good on these hills here in SW Wis.
Spike in WI
02-01-2008 05:19:20
Thanks for all of the replies. A couple of things I do have going for me is that all are diesels. I've got dealers within 24 miles of me for all of them and all are fairly close to look at. When the weather warms up a bit here I'll go and have a look. The TR 70 is in Dickeyville Wisconsin.
Jack a
02-01-2008 04:51:59
My choice would be a diesel F. Way easier for a farmer do-it-yourself fixer. They also do a real fine job.
Brett in KS
01-31-2008 20:42:36
Spike
I would look at cylinder bars, make sure they aren't wore out, new ones are $$$, and make sure none are bent. Check all of the chains, they can really add up fast, especially on the older combines, and the same goes for the belts. I myself would stay away from those bigger combines with gas engines, my little 55 sure likes to suck fuel, and a bigger combine would be worse, the $ difference between a gas and diesel would be offset in fuel savings if you plan on keeping the combine for several years.
If they have choppers, make sure the knives are sharp and check to make sure none of the augers have been rusted through, like the clean grain and tailings augers, especially if the machine has sat outside for a long period of time. I've seen lots of combines with holes rusted through in the grain tank because of water sitting in them. Do the heads match the planter you have?
Fordfarmer
01-31-2008 20:14:36
Another thing to think about is if they are gas or diesel. The TR was only available as a diesel, but I think the others could be either/or. Gassers are usually cheaper to buy, but eat up that savings in fuel in a very short time. Gear or hydro tranny? hours? Are you planning on doing small grains, corn, or both? Are you planting wide or narrow rows? Just out of curiosity, if you don't mind my asking, where is the TR? I have a NH 1400 and am kinda looking for heads.
ole/Mn
01-31-2008 17:46:23
First thing I consider when buying any thing with moving parts is parts availability. The closest reliable dealers get first choice when I'm looking. Nothing more frustrating than running a hundred miles for a two dollar part when the rain is moving in.
