Starter fluid in a diesel
T-Rev
01-18-2008 13:53:40
Rogers previous post about the gas 300 backfiring got me thinking. At work I sometimes wonder what the technique is for starter fluid in a diesel? Spray the starter fluid while also spraying WD40? I know its not good, but theres sometimes you've got to, like this Summer when we stalled a tracked Vermeer trencher crossing the live lane on a state highway job. It had set for awhile and was running rough at first. It had a Detroit, running a cutter wheel through a foot of concrete and 6" of asphalt. About two days later the rusted muffler fell off, it absolutely screamed, unlike anything I've ever heard.
1206SWMO
01-19-2008 11:59:55
 Re: Starter fluid in a diesel in reply to T-Rev, 01-18-2008 13:53:40
On cold days I have ethered the 4-53 Detroit in my 1967 Oliver 1950 tractor.The air shut off works on it in case it would run away.
With no muffler you can hear the old 2 cycle Detroits for many miles.At the pulls we turn my old 1950 Oliver 3000 rpms thru a 4 ft 4" straight pipe.
J Heitkemper
01-19-2008 21:02:00
 Re: Starter fluid in a diesel RUNNING AWAY in reply to 1206SWMO, 01-19-2008 11:59:55
Guys , I have always heard of such Horror Stories ,Never had it happen, Old Mechanic told me that Cummins Liked to do that if the rings were worn ,,And could Draw all the Oil out of Crank Case , Something to watch for , maybe he was just trying to worry Me ,chuckle , I nearly have 300 K on My 95 Dodge ,,. As Far as I know there is NO way to Shut off the Air ,,Or a Decompressor like My 800 Case has ,, Jim
cadet trooper
01-18-2008 16:54:09
T-rev I vaguely remember a story my late brother told me years ago when he was a gasoline tanker driver delivering to filling stations using Whites with Detroits to never leave them idle next to storage tank vents because two cycle Detroits had ported intakes and would run away with no way to stop them so whatever that means take it for what it's worth. I'm guessing Ether or something similar would have the same affect. I'm guessing some Detroit mechanic can shed some light on that.
