Need help installing a belt on my E-III
CraiginMO
10-07-2007 18:14:55
Got a new Header drive belt for my Gleaner E-III. Took off the old one and installed the new one on the head. Put the head on the combine and the belt is to short. Part # is correct and there was only one belt for the E-III. The K had 3 different sizes for the 13' head. I have tried everything I know. It looks to be a good 6" short. Any secrets to getting this thing on the pulleys? Thanks
CraiginMO
10-07-2007 20:54:01
 Re: Need help installing a belt on my E-III in reply to CraiginMO, 10-07-2007 18:14:55
It's name in te operators manual is the harvester belt. The parts book calls it the header drive belt. It transfers power from the combine to the header. I will measure it tomorrow. Can't see how it will ever fit the way it is now.
paul
10-08-2007 18:19:21
 Re: Need help installing a belt on my E-III in reply to CraiginMO, 10-07-2007 20:54:01
Is it located on the throat of the combine? Your first message sounded like it was out on the end of the header.
I too only know of a short chain driving the header. There is a belt driving that chain tho, is that what it is?
--->Paul
JMS/.MN
10-07-2007 21:04:01
Never saw that kind of setup- only familiar with chain drives between the combine and the header.
JMS/.MN
10-07-2007 20:31:43
I'm confused about which belt you refer to. Header drive belt is normally the belt on the left side of the combine that drives the countershaft which has a chain drive to the header. Do you mean the belt on the left side of the header that drives the auger, or a belt driving a wobble box or pitman? Perhaps someone changed pulleys, so you need to measure the old belt.
