Air Foil Chaffers
Brad Gyde
09-29-2007 20:43:53
Helping a friend... he bought a used Air Foil Chaffer for a JD 7720 Titan 2, now he is looking for one for a early model 7720 (Pre Titan II).. told they are different? (I am not too familiar with these machines.. family had them when I was too young to know much of them, and too new and big for me to be owning them)
I have never saw one in person, but it is supposed to replace the top sieve, flat on the top, approx 1/2" holes in it. Told the "cleaning apparatus" is on the botton side
He'd like to find a good used one, or a source to potentially get a new one if a used one can't be purchased. He was told have to get them from a supplier in Wisconsin now.
Any help would be appreciated guys. Thanks, Brad gydefamilyfarm@hotmail.com / 734 915 4380
Trent544
10-01-2007 18:21:04
 Re: Air Foil Chaffers in reply to Brad Gyde, 09-29-2007 20:43:53
Contact St. John Welding in St. John, Kansas. They will build an airfoil chaffer for any combine. They built one for my old Gleaner K. I run the chaffer with no sieve in corn, and run it with a 1/2 round hole sieve in soybeans.
randy hall
09-30-2007 19:07:18
i have a used rigid airfoil chaffer for $200 that i used to use for clover seed. or i can get you a new one for $425.
4435
10-01-2007 06:16:04
 Randy ? in reply to randy hall, 09-30-2007 19:07:18
What would one my 4435 deere set me back. Thanks Tom
Brad Gyde
09-30-2007 20:01:29
 Re: Air Foil Chaffers in reply to randy hall, 09-30-2007 19:07:18
Randy,
it will fit a older 7720 deere correct? If so, where are you located? I am from se MI bu currently in IL working, and if it is what he is looking for, I may be asked to swing through on my way back and pick it up.
Thanks,
Brad
Brad Gyde
10-01-2007 00:28:28
 Re: Air Foil Chaffers in reply to Brad Gyde, 09-30-2007 20:01:29
Randy,
Do you have a number I can pass along to him?
Thanks,
Brad Gyde 734-915-4380/ gydefamilyfarm@hotmail.com
randy hall
10-01-2007 17:01:14
 Re: Air Foil Chaffers in reply to Brad Gyde, 10-01-2007 00:28:28
my phone is 419 447 8825
Brad Gyde
10-03-2007 17:07:21
 Re: Air Foil Chaffers in reply to randy hall, 10-01-2007 17:01:14
Randy,
The gentleman looking for this chaffer says he cannot get through to you on the number you provided. I can either pass his to you, or is there another possible number? I just spoke with him minutes ago and now he may want 2 of them, but says he has ben trying to get ahold of you for the past two days with no luck (says it don't go to a voicemail or nothing)
Thanks, Brad
randy hall
10-04-2007 06:02:32
 Re: Air Foil Chaffers in reply to Brad Gyde, 10-03-2007 17:07:21
our home phone is 419 447 8825 it usually goes to callwave. try this number 419 937 3937, randy
randy hall
09-30-2007 20:51:40
i am located near tiffin ohio. the early 7720 and 7700 are the same, randy
bradley martin
09-30-2007 18:47:11
I believe the company that makes them is located in Manitoba, but they do have dealers scattered across N.A. Try a google search. The Case 460 pictured further up on the forum is equipped w/1.
Matthew(Mich)
09-30-2007 17:32:02
Hey Brad, just wondering if you still have that IH 80 combine that you were using on beans a few years ago? Did you have a pick-up attachment that just picked up the beans after cutting/windrowing? Or did you use it like direct cut where you had the reel that forced the beans into the cutting bar?
Matthew
Brad Gyde
09-30-2007 18:54:30
 Re: Air Foil Chaffers in reply to Matthew(Mich), 09-30-2007 17:32:02
Matthew,
I do not have it any longer. Very quick to recall it. I used it as a combine, not with a pickup attachment. What questions might you have? I ran approx 50 acres through it over 2 years time... It has been a few years, bu I still remember a lot, and I may have a book still... but ask away, and I will help as best I can .
Brad
