Pull-type combines for soybeans
mnjoe
09-28-2007 06:17:24
Pull-type combine for soybeans...how wide of cutters did they have? Only need to harvest 20-30 acres a year. Would pull with an Allis 200. If I work up a spot that was farmed years ago I will need to cross a bridge that is 17' wide. I might look for a small combine with cab. What price range would buy a small pull combine or cabbed unit. Tnaks mnjoe
MLD
09-28-2007 09:29:50
 Re: Pull-type combines for soybeans in reply to mnjoe, 09-28-2007 06:17:24
I got an Allis Chalmers 72, its 6' cut, has done well in every crop I've used it in. Just wish I could find another one that wasn't worn out.
JMS/MN
09-29-2007 11:50:52
 Re: Pull-type combines for soybeans in reply to MLD, 09-28-2007 09:29:50
You say the Model 72 is a six foot cut- makes me wonder if I've been posting wrong. Dad had a 60, then 66. I suppose I could go to the woods and measure my 66,..... ...and find the model number is the inch width of the header?!!! BTW- I might know of someone with a Model 72- if you want me to check with him- let me know.
Trent544
09-28-2007 07:24:17
I had a John Deere 42 pull type with a 9 foot cut and it worked well in soybeans. They have a narrow transport width because the header raises high and the tongue swings under it.
JMS/MN
09-28-2007 07:17:01
Few hundred bucks should get you a Model 66 AC- six foot wide pickup. Rubber shelling is easy on the beans.
rus hamm
09-28-2007 06:54:49
The allis all crops will get down to the ground real good for beans. Some of the early self propelleds i wonder about. My 91 is poor on cutting close to the ground.
