NI 315 sheller on a 311 gathering unit
Tim(nj)
08-09-2007 19:42:02
I have a 311 gathering unit which I can fix using sheet metal parts from my dead 324. The huskers on both machines are pretty much shot. I can get a decent 315 sheller to put on the repaired 311 unit. Question is, does the 315 need the 4-joint HD PTO shaft, like the 329 sheller uses? I only have the 3-joint shaft.
mnjoe
08-12-2007 21:09:04
 Re: NI 315 sheller on a 311 gathering unit in reply to Tim(nj), 08-09-2007 19:42:02
I've found 2 shellers...314 mounted to a 311 gathering picker and 314 that was stored inside with a 325 picker with a 318 grinder. Both units had the standard 540 power shaft. According to my 324-325 gathering units manual. The 4 point pto is the heavy duty 540 and 1000 power shafts. I have not seen a 329 sheller yet. According to a picture in my 329 manual I see the standard 540 pto.
Tim(nj)
08-10-2007 18:51:00
 Should be 314 sheller in reply to Tim(nj), 08-09-2007 19:42:02
315 is for a mounted picker.
