Minnie Type S,
Kirk in ks,
04-10-2007 04:54:25
If anyone look's at the pic's of the minnie?
dont laugh ok,
It was really hard to rotate them upright on this file,
thank's for looking,
Ill John
04-10-2007 10:40:58
 Re: Minnie Type S, in reply to Kirk in ks,, 04-10-2007 04:54:25
I've only got an operators manual for the SP168 and a repair manual for the S & SR. The SP168 has a rear axle that resembles a standard front axle for a U or Z. It uses the F226 Continental engine, has more modern sheetmetal covering the engine, still uses the round tank, auger looks longer, the operators station has nice sheet metal around the front and the steering wheel is slightly tilted toward the operator, looks like an updated version of the S or SR. The 168 has power steering, more like the "Brown Mule" UNIs and something called the "powerflow drive unit". The S has the same divice called a "vari-draulic drive". Those are the basic differences I see from these 2 books.
Kirk in ks,
04-10-2007 12:15:23
 Re: Minnie Type S, in reply to Ill John, 04-10-2007 10:40:58
How much you want for the repair manual for the S, and SR?
I need one, and I dont wanna GET ON EBAY ARGHHH,
If you need it ok no biggy, but if youll let it go, that Ill take it as im gonna need a copy,
to be able to work on the S,
J Wuertz
04-10-2007 07:39:39
What is the difference between the MM S and the MM SP168 combines or were they the same machine?
Kirk in ks,
04-22-2007 19:51:28
 Re: Minnie Type S, in reply to J Wuertz, 04-10-2007 07:39:39
they were later version's of the S, and SR, combine's?
redone sheetmetal and updated design,
Kirk in ks,
04-10-2007 08:02:38
Im not sure?
they might be the same model,
Ive heard of a 168 S, but didnt know it was like mine or different?
