IH engines????
Jay in Mn
01-23-2007 18:38:03
I was told that a 615"s engine would fit into a 560 with a slight modification to the oil filters. Is this true? Also, what other combine engines would fit into the 560? Thanks for any comments.
Tom Graham
01-24-2007 04:36:55
 Please don't junk a 615 in reply to Jay in Mn, 01-23-2007 18:38:03
For the engine. Find a 715, they are more common.
Jay in MN
01-24-2007 11:57:51
 Re: Please don't junk a 615 in reply to Tom Graham, 01-24-2007 04:36:55
Dont worry, I ended the deal. I was looking at a stuck 560 and wanted a little more beef for a pulling tractor, but I cant afford the upgrade. So I WILL NOT strip down a 615 or 715. On another topic I believe my uncle used a 615 up until to years ago.
Tom Graham
01-24-2007 12:12:58
 Re: Please don't junk a 615 in reply to Jay in MN, 01-24-2007 11:57:51
I have 2 both sat idle this year but were used last year.
cornfarmer
01-23-2007 19:35:06
 Re: IH engines???? in reply to Jay in Mn, 01-23-2007 18:38:03
Almost everything nees to be swapped over, at least when using a 403/715 block. Been a while since I did that, but I believe everything needs to be stripped from each block,including the manifold. Valve cover, head, and basic block are all that will interchangs. I could be wrong as I have slept a few nights since then.
sd pete
01-23-2007 18:46:19
715 is the same block. I am not an expert but i am thinking its more than oil filter differences
