Olc Combine ID
WyoDave
01-12-2007 17:22:24
Alright guys, the following are some old combines I know of around my place. I don"t know much about combines, so lets see if you can I.D them for me.
third party image
MM pull type
third party image
MM self propelled
third party image
Another MM self propelled
third party image
IH self propelled with duals, but missing the grain tank, and no header.
third party image
Old IH pull type. This one has actually been given to me, but I gotta get my Deere 5A done before I bring it home.
David
1206SWMO
01-12-2007 23:15:02
 Re: Olc Combine ID in reply to WyoDave, 01-12-2007 17:22:24
Great pictures Dave.I really enjoyed them.Thanks.
I'm no good on pull types but that could be an early 69 MM.
The SP MM's are both S's as they have the straight up and down steering wheel.The one with no beater and only a feeder chain is throwing me for a loop.My 168 lit shows a beater ahead of the feeder chain.The gas tank on a 168 is mounted in the left frame.
Do those S MM's have tricycle rears or a wide rear axle?
Thats a 123 IH SP as it looks like its had a tricycle rear.
I believe that Russ nailed the IH PT.
WyoDave
01-13-2007 04:45:09
 Re: Olc Combine ID in reply to 1206SWMO, 01-12-2007 23:15:02
The beater has probably just been removed. This farmer used a lot of MM and probably bought this machine just for parts somewhere along the way. Both S's have tricycle rear wheels.
David
1206SWMO
01-13-2007 07:52:55
 Re: Olc Combine ID in reply to WyoDave, 01-13-2007 04:45:09
Thanks for the info Dave.If you know of any I could possibly use a tricycle rear end with spoke wheels for a model S MM combine.I think that the S MM I'm looking at in eastern Kansas originally had a tricycle rear with spoke wheels as it has spoke front wheels.
On that S MM with no beater it almost looks like the feeder chain is too close to the platform auger to allow room for a beater.
71ford100
01-12-2007 19:15:28
Okay either mm 69 or 88, i think the sp mm"s are both s, ih 123 and no clue on the pull type. Are these the MM combines you were telling me about when I got the 27.
WyoDave
01-13-2007 04:46:10
 Re: Olc Combine ID in reply to 71ford100, 01-12-2007 19:15:28
Yep, those are the ones. There are a couple more pull types that have pretty well been dismantled for parts along the way.
David
lucasd
01-12-2007 18:02:44
Maybe I am wrong, but the SP MM combine with the beater on the head is an SP-168 and the other is a straight "S". I'm pretty sure that the 168's had the beater on the head. Don't know if the S did or not.
Lucas
russ hamm
01-12-2007 17:43:53
that last ih pull type is a 22 i think. otherwise i don.t know the rest. i have a 20 like it but galvanized. maybe later painted model i'm not thinking of?
WyoDave
01-12-2007 17:25:52
 OOPS Can't even spell OLD in reply to WyoDave, 01-12-2007 17:22:24
n/m
