Farmer,I have original Case SP-12 sales lit and here are the dimensions for a regular SP-12.The weight isnt listed but I'm guessing some over 9,000 lbs but not quite 10,000 lbs since its a hillside model. The width is 13'5" with the platform on.Its about 9'6" wide with the header removed.The height is 12' but the clean grain elevator could be taken off to lower it to 10' or so. The length is 24'3". A good heavy duty flatbed (preferably no fenders) or gooseneck 20-26 ft 2-3 axle trailer capable of carrying at least 10,000 lbs will be needed. On a car type trailer I pull them on forward and have to remove the right side combine tire on the wide ones like a Case..I use a floor jack on the trailer to get them over the right side trailer fender.You can either set it on good blocks or put the tire back on.
Heres the reason most people dont collect old combines.The bigger ones can be a real pain to haul.
