Picture-Chance To Buy An S MM Combine On A Sale
1206SWMO
11-25-2006 19:47:12
This afternoon we went over to Kansas to check out an upcoming estate sale that had an old MM combine.I had a feeling it was a SP and sure enough its a model S MM thats probably sat in one place for over 30 years.The only wheel on it is the left driver.
Theres also (2) 45 JD's and a decent Gleaner 6 pull type.
iowa_tire_guy
11-26-2006 12:44:09
 Re: Picture-Chance To Buy An S MM Combine On A Sal in reply to 1206SWMO, 11-25-2006 19:47:12
What's a Gleaner 6 pull type? My Dad used a couple Gleaner pull types in the 50's that had a 12 foot header. Would this be one like them?
1206SWMO
11-26-2006 15:42:50
 Re: Picture-Chance To Buy An S MM Combine On A Sal in reply to iowa_tire_guy, 11-26-2006 12:44:09
I'll start another topic and show a picture of the Gleaner 6.
71ford100
11-25-2006 20:18:53
Dang if I was closer I would be after that just cause its MM
1206SWMO
11-25-2006 20:35:08
 Re: Picture-Chance To Buy An S MM Combine On A Sal in reply to 71ford100, 11-25-2006 20:18:53
If I get this one its going to be almost impossible to load it.Youd need a tilt bed.It will take a chain saw just to get to it.If I get it I may just strip it down as its pretty rusted out.I can buy a better one 100 miles away minus the rear axle which this one has.This one is 60 miles away.
It wouldnt take long to pull the engine,radiator,rear axle,header,seives,left wheel,etc.Grain bin and unloading auger are rusted out.
IHC Red
11-26-2006 19:01:28
 Re: Picture-Chance To Buy An S MM Combine On A Sal in reply to 1206SWMO, 11-25-2006 20:35:08
You just about got that posting thing... if you put the URL exactly as you've got it formatted into the "Option Image URL:" field instead of the "Optional Link URL:" you'll have it showing up in the post.
I love those old combine pics. Keep 'em coming.
120SWMO
11-26-2006 19:22:57
 Re: Picture-Chance To Buy An S MM Combine On A Sal in reply to IHC Red, 11-26-2006 19:01:28
third party image
RED,I'll try it one more time.I've been putting the bottom one from photobucket in to the bottom one here but nothing happens.
WyoDave
11-26-2006 19:26:30
 Re: Picture-Chance To Buy An S MM Combine On A Sal in reply to 120SWMO, 11-26-2006 19:22:57
Try once more, but use the top one from photobucket in the bottom box on this site.
David
1206SWMO
11-26-2006 19:34:20
 Re: Picture-Chance To Buy An S MM Combine On A Sal in reply to WyoDave, 11-26-2006 19:26:30
third party image
Lets see what happens.Ditto,it works.Thanks Dave.
