McCormick 91 w/C-135 engine
smirkey
09-27-2006 10:48:33
two questions. we've had this old 91 in NE Pennsylvania for about 10 years and don't use it much or not at all. I try to start and run it one a year. cost me about $125 for a 6 volt electric fuel pump last year. this year the carb float was stuck. now i ruined the carb gaskets and will need to rebuild the carb. any ideas where i can get the carb kit for a c135. are there more than one type of carb? also do you think i could sell the power unit for a few hundred dollars, it runs nice. i don't think anyone would actually buy this combine to use since its old and you know about parts and such. but the engine would run something else and much easier to haul. what would you guys do?
russ hamm
09-27-2006 15:23:12
 Re: McCormick 91 w/C-135 engine in reply to smirkey, 09-27-2006 10:48:33
smirk, if is not completely worn out, the 91's are pretty collectable. and parts combines are around. you are right about the size. smallest self propelled ih combine made and easy to haul for the most part. we used ours this summer for about 4 hours or so with two minor welding breakdowns. it was a lot of fun for a small acreage. pretty dusty though. fix 'er up.
