Painting Crop Dividers
pbutler
05-09-2006 06:56:28
I am fixing up an older JD 220 platform. There is some rust on the dividers. I would like to repaint them. On my old combine I sanded, primered (white primer), and painted it. After a couple days in the field the paint rubbed off and you could see the white primer all over the place-looked terrible.
Anyone ever successfully painted those and got it to "stick"? Any tricks?
JHEnt
05-11-2006 16:22:49
 Re: Painting Crop Dividers in reply to pbutler, 05-09-2006 06:56:28
sand the rust down and then just spray the green on. Don't thin the paint as much as you would think you should. It will take more green paint to get good coverage but you won't have the primer wear through.
Bruno
05-09-2006 07:33:54
The paint will wear off regardless from constant contact with the crop. Just paint them green at the end of the season with no primer. The same thing happens on corn snouts unless you replace them with poly ones.
