Small pull-type combines
JZC
03-22-2006 19:40:32
I'm trying to educate myself about small pull type combines, suitable for trailing behind a Ford 9N or similar small tractor with reletively low pto hp.
We'd like to plant about 5 acres in wheat - probably not every year, so I don't need a big, fast, wide, high reliability machine. Old, small, simple and fixable is what I like.
Can anyone reccomend some reference materials covering this sort of combine?
I read about machines on this forum selling for $500 - $1000 that could be OK, but without a good reference it's difficult to know.
RickL
03-25-2006 12:12:28
 Re: Small pull-type combines in reply to JZC, 03-22-2006 19:40:32
I have a pair need to get rid of both one owner machines that have been shedded alll there lives. Ac 66 and IH with its own motor
JZC
03-24-2006 12:53:29
Thanks everyone for the good ideas.
I will ponder these suggestions over the weekend and try to produce a summary table for general distribution.
I"ve noticed that I"m not the only one looking for these things, but almost no-one is making new ones, since there isn"t any way to make a profit making them.
In the mean time, the more suggestions for small combine types to research the better!
Keep those cards and letters coming in!
Thanks;
JC
BERT64
03-24-2006 04:48:36
I pulled a A/C Allcrop 60 for several years with a JD 40, About 25 hp. Biggest problem was not hp, but lack of live pto. When pushed the clutch to stop, everything stopped.. Found an A/c power unit and that solved the problem. Although running the tractor and power unit did suck up right much gas. Allcrop 60 was a great machine. Bert
cockshuttguy
03-23-2006 08:18:29
I'd get an AC All Crop 60. Best for its size and the ole 9N will run it. 500 georges should get you a good unit.
Have fun.
tim[in]
03-22-2006 21:16:15
one neighbor used an allis all crop with a ford jubilee to do custom combining for years around here.pto or engine i dont know. he moved away years ago.
msb
03-22-2006 19:53:26
For a 9N you will probably want a combine with its own engine on it.If you could go up a bit in horesepwer and find a tractor capable of operating a remote hydraulic cylinder to lift the platform, then there is a John Deere 30 listed for sale at photo ads.It looks to be in good condition.The JD 30 is a good auger machine and then canvases would not be a problem for you.
JZC
03-22-2006 20:27:25
 Re: Small pull-type combines in reply to msb, 03-22-2006 19:53:26
Thanks for the hint - took a look - will add JD30 to my list of possibles - found a reference to JD25 that uses canvas - maybe will come up with my own reference book eventually.
If possible, would prefer to keep the 9N and get a combine with it"s own motor, like Dearborn-Woods from late 40"s, but I realize that moves me into bigger stuff that is harder to move.
I"m in Vermont, and know that there will be a long drive in a flatbed involved here eventually.
Super A
03-23-2006 05:09:31
 Re: Small pull-type combines in reply to JZC, 03-22-2006 20:27:25
You could run an IH 42R with a 9N, they were rated for a 1-2 plow tractor minimum. I'd think you could probably handle a 52R as well, it's just a newer 42R with a 5' cut instead of 4' on the 42R. Also you can find some 52R's with Continental or IH Cub power units. These combines were built from 1940-1951 so they're canvas feed, but they do a nice job. I have three (two for the field and one for parts) that I "play" with.
Al
