McCormick IH 127 SP combine
Neil Vonnahme
01-02-2006 17:58:07
New to this looking for info. I recently pulled a McCormick IH 127 SP out of our shed thats been there for years. I'm wanting to get it running and restored hopeing someone would have any info on were I could find parts decals information on this model. Is this a rare model or just not popular cause I can't find any info on it anywhere. noone even talks about it. any info would help and if anyone has any tips on must dos before trying to start it would be appreciated. Also there is a mccormick pull type swather/ windrower any info on that would be great.
Tim Malin
02-24-2006 10:42:46
 Re: McCormick IH 127 SP combine in reply to Neil Vonnahme, 01-02-2006 17:58:07
Nice to see you are keeping that old thing in the corner to fix up. It is so cool that all these old combines are being fixed up today, we need them for our history!!! Take care, good luck on everything! May it combine forever!
Albert Grindle
01-02-2006 22:23:49
Neil you have one of the rarest full-production combines ever. The 127s were part of the 1st series McCormick made and I would venture to guess parts would be very hard to come by. Motor parts (if needed) shouldn"t be too hard, but if there is any sheet metal work you"ll probably have to do it yourself. I must say if you do give up the project I GUARANTEE someone on this board will give her a good home!!! GOOD LUCK And let us know how your restoration goes!
Neil Vonnahme
01-03-2006 05:54:40
 Re: McCormick IH 127 SP combine in reply to Albert Grindle, 01-02-2006 22:23:49
Well thats good to know Albert thanks for replying. The good part is that my great uncles always had it sheded. The engines not locked and everthing on the machine you can turn by hand. The only tin work that is needed is the bottom side of the tailings return elevator and the platform behind the seat where the coons made their outhouse. Still wondering where I might find decals for this machine though.
Albert Grindle
01-03-2006 21:57:08
 Re: McCormick IH 127 SP combine in reply to Neil Vonnahme, 01-03-2006 05:54:40
You're gonna have to get the decals custom made, which is pretty expensive (unless you have connections). The decals believe it or not are going to be the most expensive part of my McCormick 101 project by a landslide.
1206SWMO
01-03-2006 16:55:11
Neil, Sounds like you have a great old combine there.The 127's were built from 1952-54 and are pretty rare.I have original sales lit for them.My Dad used to have a 1940's model 123.
I'm sure there are a few parts machines around somewhere.Doesnt sound like you need very much.Its always much easier to restore them when they've been shedded.
Cant help you on decals but I have seen pictures of restored 123's.
Neil Vonnahme
01-03-2006 20:00:48
 Re: McCormick IH 127 SP combine in reply to 1206SWMO, 01-03-2006 16:55:11
thanks for the info been getting into the engine right now every time i turn around theirs something i need luckily enough the local case IH dealer has been able to match part numbers on the little things need some repair on the radiator hopefully that can be fixed and I dont have to find a new one hoping to get a before picture put on here before i tear anything else off
Averyman
01-02-2006 19:14:35
You have an oldie there... in 1975 I acquired a 127 and a 125 and used one chassis to mount a 11" x 60' grain auger on it. The "Green Diamond" motor was seized at the time but was not hard to loosen up and is still serving us well today. I believe the only difference between the two models was one had a wide rear axle and the other a tricicle setup. Rather strange! Somewhere in my "stuff" I believe I have an operators manual, I'll try and find it if you're interested. Clarence
Neil Vonnahme
01-03-2006 05:58:07
 Re: McCormick IH 127 SP combine in reply to Averyman, 01-02-2006 19:14:35
Thanks Averyman I already have an operators manual and a parts book for this machine. was lucky enough my older relatives shoved every book they had in a filing cabinet and their they sat. Thanks anyway aavery
