Platform feeding question for you!
newyear
12-31-2005 07:44:08
What do you combine owners use to clean up a rusty or painted grain platform that feeds to the center in bunches? Chemicals? Powered sanders & grinders? Maybe a lubricant to assist in shinning things up? Thanks in advance!
TDS
01-02-2006 17:27:13
 Re: Platform feeding question for you! in reply to newyear, 12-31-2005 07:44:08
I use graphite powder, like what u put in planter boxes to lub and shine the plates. I jsut pour powder all over the header floor then whent he crop slides over the floor it will rub the powder and take off the rust. ALso you could use a corncob and dip in in kerosene and rub it on the rust, which will make it smooth. Or theirs somekinda acid that will take the rust off , but not damage the metal i jsut cant think of the name.
TDS
JMS/MN
01-03-2006 08:59:25
 Re: Platform feeding question for you! in reply to TDS, 01-02-2006 17:27:13
Muriatic acid?
bh
12-31-2005 08:30:03
To just assist in the feeding, the single best thing you can do is to square the auger flighting like a new one. Take a grinder and grind the edge of the flighting back square just like it was when it was new. If you notice on a worn auger the tip of the auger flighting against the crop will be rounded. You want to grind it down past the round part. I hope this makes sense, and some will ridicule me for it, but I promise that it can make a machine feed like a new one. Also, be sure that your auger is adjusted to the correct clearance specifications. BH
Averyman
12-31-2005 12:15:32
 Re: Platform feeding question for you! in reply to bh, 12-31-2005 08:30:03
You"re right BH, we do that on all our machines. Also, make sure the stripper bar behind the auger conveyor is in good shape. So often a conveyor gets bent or broken and damages the stripper bar. The conveyor gets replaced or fixed and the stripper bar that has been damaged receives no attention...
