Plans to convert running gear to head hauler
Lee in Wis.
09-04-2005 18:48:46
I have an old Colby (wondering when they were made?) running gear I put 185/60x14 tires on it so it's low profile. I'd like to make a transport for a 13-15' MF bean head. Any suggestions appreiciated, Thanks....Lee
RickL
09-15-2005 05:57:34
 Re: Plans to convert running gear to head hauler in reply to Lee in Wis., 09-04-2005 18:48:46
talked to you earlier in regards to my head carrier. the running gear got sold but the frame work that was used for the head is still here if you would like to set it on your gear. $50.00
ILL John
09-06-2005 18:58:23
Lee, I have literature from '50 and '53 on the Coby Company. My Grandad bought a new Coby in '49, probably the best, most expensive wagon made then. I have 2 Coby 21-As, they are the "tapered" frame design, 7' x 14' flat with removable sides, also have a 31-A which is a self contained hyd dump wagon, powered by a PTO pump/cylinder built into the frame. If yours has a conventional gear, it'd be a 11-A, 3 ton capacity. they were products of the Perfection Steel Body Company. John
Lee in Wis.
09-07-2005 18:14:59
 Oops! I need glasses or quit drinkin' in reply to ILL John, 09-06-2005 18:58:23
Thanks for the info on coby gears. I went out to check because I thought it was colby.....It"s a Clark Cutaway (since1856) Harrow Co. name on it! Dont"t know where I got other name from-----guess it"s just old age (46). Thanks to everyone for other comments.....Lee
Butch(OH)
09-06-2005 07:38:31
B-in-law has two header carts for his rotor Case that are nothing more than older light duty wagon gears with $100 worth of lumber and bolts added. The back of the grainhead rests against the bed standards already on the bolsters. I think I have the name right "standards" The metal tabs that are on any running gear to bolt a bed to? On the opposite side we a bolted a treaded 4x8 to raise the front up to the angle of the head. Took about 1 hour to "build" The gear for the cornhead has an extra plank added on top of the 4x8 to get the angle right. A picture might help my lousy discriptions, post if you want me to take some pics.
JMS/MN
09-05-2005 19:54:18
One outfit to check with is Hiniker Company- Mankato, MN. Also check the product line of May-Wes.
RickL
09-05-2005 18:12:16
I have a unit I built that I would sell you, I used it for a 15ft jd head. Als there are kits available that would be very reasonable also look in any farm magazine,the name escapes me right now thou,but like I said I do have a unit that would work for you. It just sets onto any wagon running gear. I don't need anymore.$100.00 or three hundred for gear and all.
