Redekop Chopper
Doc Holiday
06-19-2005 07:40:26
Does anyone have any experience with Redekop choppers on axial flow combines?
I"ve got a 1480 without a chopper and before I drop $3000.00+ for a oem chopper (which it sounds like a lot of people are not satisfied with) I am thinking on a Redekop as there isn"t that much difference in price.
Has anyone ever run across any used Redekop units?
Doc Holiday
James2
06-22-2005 10:22:33
 Re: Redekop Chopper in reply to Doc Holiday, 06-19-2005 07:40:26
I also have a 1480 and have looked at a TSR rather than a Redekop. The TSR's fit in where the OEM's are installed and are slightly cheaper than either the OEM and Redekop. I heard the Redekop require a lot of hp. Haven't heard anything bad about TSR, but maybe I'm not listening hard enough.
Doc Holiday
06-22-2005 20:07:22
 Re: Redekop Chopper in reply to James2, 06-22-2005 10:22:33
James -
I've looked at the TSR as well.
But it seems like most of the guys are unhappy with the choppers even on the newer combines.
I think it all comes back to unless those spinners are running 1000rpm and the chopper has it ground into pulp before it hits the spinners you just aren't going to get results like a conventional combine/chopper.
I just don't want to spend $3000+ and end up with something I'm not going to be happy with...lol
If you get a TSR chopper, I'm real curious how it works out for you.
Thanks for the response!
Doc
