Storing Combine-Head Position
pbutler
03-18-2005 05:11:45
If I want to store my combine over the winter/summer with the corn head on (still moving a lot of stuff around in shed as wiring happen, etc. is there any harm in leaving the head up?
Seems like it would be better at keeping rodents out of machine, but didn't know if a couple months of constant pressure on hydraulics could possibly hurt anything.
Kent of SW MO
03-21-2005 07:44:30
 Re: Storing Combine-Head Position in reply to pbutler, 03-18-2005 05:11:45
I store my combined with the feeder huose up setting on the saftey the bleed off the hydrulics.
Kent
Superpicker
03-19-2005 12:53:03
Set your head down on some blocks and take the hydraulic pressure off the system. It will be easier on the seals in your cylinders.
Bruno
03-18-2005 07:15:44
Just set the head down, back off a foot or so, then raise the feederhouse and set the safety stop. When you need to move the head, you'll be lined right up to hook up.
Unless you hang the combine from the ceiling, the mice will still find away to get in. I leave every possible door or cover open and run the machine every few weeks to keep them from setting up shop.
JMS/MN
03-18-2005 07:58:25
 Re: Storing Combine-Head Position in reply to Bruno, 03-18-2005 07:15:44
I've found mothballs or flakes help to keep them out of the cab. I remove some displays in the Gleaner headliner and put them behind the units.
Bruno
03-18-2005 08:39:36
 Re: Storing Combine-Head Position in reply to JMS/MN, 03-18-2005 07:58:25
I"ve had good luck with Bounce fabric softener sheets-smells nicer too!
