Minniapolis pull type
Farmall43
03-10-2005 12:44:53
Found a minniapolis pull type combine that I may be getting as part of my line of work. It is in fairly rough conditi0n.. If there is a need for parts let me know and If I get the clean up bid maybe someething can be worked out.
grandfield
03-10-2005 17:24:37
 Re: Minniapolis pull type in reply to Farmall43, 03-10-2005 12:44:53
Really be helpful if you could post the model and approximate region. Most of these combines had a 3" x 5" tag near the rear with the model and serial #. Thanks, John
Farmall43
03-11-2005 06:44:48
 Re: Minniapolis pull type in reply to grandfield, 03-10-2005 17:24:37
I should be back out their next week. Until I seen it I did not even know that they had made pull type combines. Located about 25 miles WSW of Lansing MI.
grandfield
03-11-2005 17:08:55
 Re: Minniapolis pull type in reply to Farmall43, 03-11-2005 06:44:48
Alittle too far for me to pull a combine, don't think it'll float either. There are MM guys in your area though, maybe one of them will be interested. Could be a H-3 which is the "69" model, or an 88, both refer to the width of cut. Thanks, John
