Information on walk behind [ Bear Cat ?] garden tractor.
Bear cat
01-02-2000 19:01:50
I have a walk behind garden tractor, that I was given to by my dad and grandad.The motor sets at the front of the frame and the gear housing sets off to the side of the frame..it has a fuel pump like you would have on a older car,with a setlement bulb on it..My dad and grandad says it is a Bear Cat...I have found sone information on this kind of garden tractor only once sence I got it...in a book of fieldtesting?,,,If any one has any information to help please post....thanks
Don
01-04-2000 18:00:42
 Re: information on walk behind [ Bear Cat ?] garden tractor. in reply to Bear cat, 01-02-2000 19:01:50
First 2 numbers should be year--a dash a number(month)-then serial number or at least thats what I have been told.
jerry
02-08-2000 10:54:19
 Re: Re: information on walk behind [ Bear Cat ?] garden tractor. in reply to Don, 01-04-2000 18:00:42
thanks for the information on what the numbers represent and where to find them. does anyone make a decal as i would like to restore this tractor. thanks
Karl in MD
01-03-2000 17:24:50
If the engine tilts to tighten the drive belt then it's probably an Ellinwood bearcat made in the late forties during the garden tractor boom. the Bearcat was tested at Nebraska and you'll find a picture and test results in C.H. Wendel's Nebraska test book.
jerry
02-08-2000 11:06:33
 Re: Re: information on walk behind [ Bear Cat ?] garden tractor. in reply to Karl in MD, 01-03-2000 17:24:50
where can i get a copy if C.H. Wendel's test book?
Don Elgan
01-03-2000 17:53:30
Look down on the frame (side), on the right side as you stand behind it, just in front of the motor you will see some numbers, that will tell you the year it was made. You may have to clean some dirt to find it--the numbers are big. I'll have to go out to look at mine to be able to tell you what part of the number tells you the year.
Chris in Sherwood
01-11-2000 18:00:01
 Re: Re: Re: information on walk behind [ Bear Cat ?] garden tractor. in reply to Don Elgan, 01-03-2000 17:53:30
I have a '47 Bear Cat walk-behind tractor with the plow, disc, blade, and cultivator attachments. It has the tilt-engine method of belt tension. It used to be a real workhorse. I want to restore the poor thing, so if any other owners happen to have literature on this type garden tractor I would sure love a copy.
