JD 318 hard starting
appraiser
04-21-2008 11:16:19
I posted this in the John Deere forum but will ask here also. My 318 has to crank & crank and will not start. If you pull the choke out or give it some throttle it will act as though flooded?? The only way I can start it is to open air cleaner & pour a little fuel right in to carb. and it starts right away. I replaced fuel pump last year and it helped some but not a lot. What am I doing wrong? Thanks for your help.
Kentb of SWMO
04-22-2008 05:45:11
 Re: JD 318 hard starting in reply to appraiser, 04-21-2008 11:16:19
Get some spray carb cleaner. I use WallyWorld brand. Spray into the carb and try to start your ONAN engine. If it atarts and runs for a time, you have a fuel problem. If it does not start you have an ignition problem. Then you know which direction to go.
Kent
El Toro
04-22-2008 05:37:48
Sounds like you're not getting fuel to the carb. Hal
cadetpwr
04-21-2008 18:54:48
I would start with a new set of points and condenser. Hard starting and acting like its flooded is a sure sign of an igntion problem. Replace the points with genuine Onan parts, set the gap to spec and see if that helps. I had to replace the points and plugs in a 982 cub cadet that has the B48G Onan, same as the 420 JD power plant. She was quite hard starting prior to that. Nice thing about Onans, you can fine tune the point gap while its running, cant do that on a Kohler or Briggs that I know of. Cheers Mike
steve in in
04-21-2008 11:43:12
I would take a stab at the carb, though at $76 for the rebuild kit, its an expensive stab. I haven't coughed up the money to do it for mine yet.
That kind of money is hard to give up considering the rebuild kits for the 8 and 10 hp Kohler's are only about $11 from a Kohler dealer.
Can we assume you changed the fuel filter, whether it looked like it needs it or not?
appraiser
04-21-2008 12:52:37
 Re: JD 318 hard starting in reply to steve in in, 04-21-2008 11:43:12
Thanks, I will look at any ideas. It is only hard to start the first time after a week or more of sitting. Once started it runs great.
balatonm
04-21-2008 11:24:09
it could be the fuel line or the carb it self. just my 2 cents.
