Need a regulator for a JD 140
betty ford
04-07-2008 19:19:22
Is there a good place to find a rectifier/regulator for a JD 140? Seems there were two types offered and I guess either would work if I had the pigtail from the tractor.
Thinking that most tractors of this vintage using a Kohler K321 might have the right part.
Used to have a mower salvage place near me but I think they shut down...
Thanks for any ideas!
Ken
betty ford
04-17-2008 11:10:09
 Re: Need a regulator for a JD 140 in reply to betty ford, 04-07-2008 19:19:22
It's looking like I might have been in a rush!! I followed the chart in the service manual and it looks as though the ign switch IS the problem. I hooked a meter to the pos batt cable and all is good except the switch term that goes to the reg.
Anyone know the part number of the switch?
Thanks,
Ken
betty ford
04-09-2008 07:21:46
Thanks guys!
I have AC voltage of about 32 volts coming from the engine but the DC terminal on the reg is giving me nothing at all measured directly on the terminal, so it looks like it's the reg that's bad.
Sorry but I don't have the serial number and keep trying to remember to look at it! Tractor just got removed from the garage to make way for another repair job. The regulator on it is not the one with wires coming out of it so there is a two terminal plug that plugs into it from the ac windings, and a single terminal that carries the DC+. No fuse on it either like the one style has.
Ken
El Toro
04-09-2008 15:05:17
 Re: Need a regulator for a JD 140 in reply to betty ford, 04-09-2008 07:21:46
third party image
Your rectifier/regulator is like this one in the diagram. Hal
PS: Did you clean the center terminal until shiny?
El Toro
04-08-2008 15:52:18
I had a JD 140 and the amp meter didn't show any charge even though I had ac voltage from the stator. I found the terminals on the regulator needed to be cleaned. Then it charged. Hal
Bob
04-08-2008 16:16:07
 Re: Need a regulator for a JD 140 in reply to El Toro, 04-08-2008 15:52:18
It's just as likely the ignition switch is shot, or the terminals are dirty. The charging current passes through there on it's way to the battery,
IH2444
04-08-2008 14:13:34
I got an aftermarket VR for my K301 for about half the price Kohler wanted. works great and has a bigger heat sink. I will see if I can find the link.
Still about $40 as I recall.
Bob
04-08-2008 13:16:34
Why don't you just get one from the Deere dealer?
Up through serial number 38,000:
Part #AM123296 (comes with connector)
Serial number 38,001 and above:
Part # AM37200
Do you KNOW what your tractor serial # is???
BUTCH GA.
04-08-2008 05:12:54
Ken give Lundell Tractors a call at 712-675-4341 I get my parts from them for my 110's great people to deal with they are located in Kiron Iowa.
Butch
