Re-Wiring Case 222-Starter Generator-
Art Francis
04-01-2008 13:59:49
Gents
I'm restoring a 76, Case 222, all's finished but the wiring, oil & misc stuff.. I bought a manual but it does not have the schematic for a starter generator system, no stator.. Help Much Appreciated
Thanks
Art
Tom Arnold
04-04-2008 09:51:58
 Re: Re-Wiring Case 222-Starter Generator- in reply to Art Francis, 04-01-2008 13:59:49
If you have guessed wrong, then kiss your $80.00 regulator bye-bye.
El Toro
04-03-2008 03:53:28
third party image
This may diagram may help. Hal
El Toro
04-01-2008 17:09:25
I don't know if this diagram will help you, but my tractor does have a starter/generator with a starter solenoid. It cranks CW and has an amp meter. Hal
third party image
third party image
Tom Arnold
04-02-2008 17:07:35
 Re: Re-Wiring Case 222-Starter Generator- in reply to El Toro, 04-01-2008 17:09:25
Unfortunately, your diagram does not apply for at least two reasons. Your Monkey Wards unit uses magneto ignition. Kohlers use coil ignition. Your regulator has three terminals. Case regulators have four.
Tom Arnold
04-01-2008 16:37:46
If you had the Operator's Manual that covers the serial (PIN) of your tractor, then you would also have the wiring schematic. You can obtain one of those manuals from Ed at the link below.
Send me a fax number via my email address and I will send you a copy of the wiring diagram. Just tell me whether your tractor has an ammeter or gen light.
n2deep
04-03-2008 18:03:33
 Re: Re-Wiring Case 222-Starter Generator- in reply to Tom Arnold, 04-01-2008 16:37:46
First I want to say thanks for the help, this is truly a great forum thanks to people like you.I believe I have it figured out,, will put the battery in it tomorrow and give it a spin
Thanks Again
