JD 445-New Problem-please help
big red 1
03-28-2008 12:33:25
Hi I just posted the PTO problem,Now I cant get it started no spark at either cylinder
Any ideas
thanks in advance
Randy
jd b puller
04-01-2008 17:16:50
 Re: JD 445-New Problem-please help in reply to Kentb of SWMO, 03-28-2008 12:33:25
Shouldn't be the seat. You have to have the brake on in order to crank it. If the brake is on, seat doesn't matter...
Time delay module would be a good candidate, they're cheap and easy to repair and they are one of the high failure parts.
Mike M
04-01-2008 11:48:02
 Re: JD 445-New Problem-please help in reply to big red 1, 03-28-2008 12:33:25
DOUBLE CHECK THE SEAT SWITCH.
chvy65
03-29-2008 21:12:12
Sounds like a bad time delay control module
At starter solenoid follow red wire to a module that has a long black wire a short yellow and orange wires
This is the time delay control module It can go bad and give intermitant spark or no spark
A cheap easy fix See ur local dealer for part
Older modules were square but new ones are round
Good luck Gary
jd b puller
03-28-2008 19:18:43
 Re: JD 445-New Problem-please help in reply to Steve Johnson, 03-28-2008 12:33:25
big red 1 said: (quoted from post at 15:33:25 03/28/08) Hi I just posted the PTO problem,Now I cant get it started no spark at either cylinder
Any ideas
thanks in advance
Randy
Randy, did you resolve the PTO problem yet? IF not, do you have power at the solenoid? You need to have the key on, in the seat, brake off, and pto on (in that sequence). Have someone check to see if you have power/ground at the solenoid at the rear of the tractor.
JT
03-28-2008 18:19:04
You had better go find a service manual on this, unless you knocked a wire loose if you were messing with PTO switch. That series of Deere has all kinds of relays, time delay relays, switches, control modules, etc. Jim
Cubs Gone Wild
03-28-2008 16:11:20
Why don't you solve all your problems and buy a CUB CADET!! Can't go wrong there!!
El Toro
03-28-2008 14:40:01
Are there any safety switches on the tractor that
will prevent the engine from starting? You may need to jumper them to find the defective switch.
Hal
Dude11
03-28-2008 12:43:25
What did you say you ate for lunch??Step back and take a good look at what you got here,maybe a loose or broken wire.Sometimes it's the simple things I overlook.Dude11
