Simplicity 725- Is it a Puller or not?
apz*jr
11-21-2007 05:04:41
I am restoring a Simplicity 725, and want to know if it is a good garden tractor pulling tractor. I am not using it for stock pulling, and want to know if it is a good puller before I break it or something trying to pull with it. I posted this on the Tractor Pulling Forum and didn"t get any luck with a response, so I am hoping for more luck in this one.
Thanks for all the help!
chuck in Indiana
11-21-2007 14:19:02
 Re: Simplicity 725- Is it a Puller or not? in reply to apz*jr, 11-21-2007 05:04:41
Yes they make good pullers.We have 2 that we've been pulling sence the early 70's. They only weak spot is the set of gears that conect the two axles together on the right side of the rearend.We had a adaptor plate made for one to replace it and lock the rear end.The other we had a solid axle made that replaced both the inner and outer axles.
paulatclf
11-21-2007 08:03:04
I had a 725 also. Too nice in my opinion to modify for pulling, but real strong with a real trans. Felt like it could pull all day long if traction wasn't an issue. If your tractor isn't perfect cosmetically--then I say go for it!
Karl Brandt
11-21-2007 05:14:38
Hello,I also have a Simplicity 725 tractor.
This tractor is the second model Simplicity made and highly collectable tractor.
This tractor was made 1961-1963.
I have over 35 Simplicity & Allis Chalmers tractors....I do not pull with any of them.
I use them for snow plowing,cutting grass,rotto tiller the garden,etc.
I think a bigger tractor with more hp would be good for pulling. Karl
