JD 111 rearend needed other models that will fit?
BIG RED 1
10-23-2007 14:35:28
Iam looking for a good hydro rearend for my 111
what other models would fit this transmission? Mine has the pulley on the side
thanks in advance
Randy
leon
10-24-2007 03:34:46
 Re: JD 111 rearend needed other models that will fit? in reply to BIG RED 1, 10-23-2007 14:35:28
I replaced a hydro transaxle on a 111H not too long ago, not so sure now that it was bad, but in the course of coming up with a replacement found that to the best of my knowledge the 111H's hydro transaxle is essentially the same as is used in the 112L, 116H, 165, 175 and 185 before #372001. By the way, you can have that transaxle I took out if you will come and get it. I've also found that time can be bought for a hydro unit that is slipping by using a heavier oil than is specified. I think the 111H specifies SAE 20W, and I have found that 10W-40 cures them at least for a while. Also be aware that on these units the hydro unit's oil reservoir is separate from thee differential which uses heavier oil, like maybe 80W-90 or GL5.
BIG RED 1
10-24-2007 11:59:44
 Re: JD 111 rearend needed other models that will fit? in reply to leon, 10-24-2007 03:34:46
leon were are you located?
leon
10-24-2007 19:03:14
 Re: JD 111 rearend needed other models that will fit? in reply to BIG RED 1, 10-24-2007 11:59:44
I'm located in Cedar Falls, IA. Where are you? You could e-mail me via this site.
big red 1
10-25-2007 06:26:29
 Re: JD 111 rearend needed other models that will fit? in reply to leon, 10-24-2007 19:03:14
No kidding Im in Cedar Rapids Ia.
Boyd in Mn
10-23-2007 21:57:24
JD 116 was the same chassy. I think they made a 108 on that chassy also,, but not sure.
Dave in Tx
10-23-2007 19:41:05
Do you just need the hydro unit or the whole thing?? Might have a used hydro.
Dave
xPosTech
11-01-2007 06:45:24
 Re: JD 111 rearend needed other models that will fit? in reply to Dave in Tx, 10-23-2007 19:41:05
Dave in TX
I need a TuffTorq K51E Hydro for a Scotts (Deere) S2046. I'm sure if the JD 111 is not exact I can probably make it fit. If I can't find a reasonable used unit I will have to open the one I have up but parts aren't available. This unit failed at 260 hours. Anyhoo I'm the Beaumont area.
Ted
