Cub Cadet 1864
archambault
08-30-2007 06:40:19
Tractor won't start. The indicator light says that the PTO is engaged. The switch is in the off position. I disconnected the wires to the PTO switch and the indicator still says to disengage the PTO. The pulley that drives the belt moves freely and will move the belt when turned by hand.
El Toro
08-30-2007 07:11:22
 Re: Cub Cadet 1864 in reply to archambault, 08-30-2007 06:40:19
I would reconnect the wires to the PTO switch and then jumper the switch with a piece of wire. The switch may be defective. Then see if the engine will start. Hal
