John Deere 345 Loses Power
Belini
05-13-2007 18:56:02
My JD 345 starts Ok. Idles OK. Runs under full throttle with load for about 30 seconds then
loses power & RPM's. Stop blades and idles ok.
Start mowing again and goes through the same.
Ok for a few seconds. I've done the obvious.
Changes fuel filter. Drained Carb. Took tank off
and cleaned. Put in clean fuel. Blew air fuel fuel line. I'm sure its not getting fuel.
But why? Is new fuel pump next?
Belini
chevy65
05-14-2007 08:58:50
 Re: John Deere 345 Loses Power in reply to Belini, 05-13-2007 18:56:02
If ur sure its not getting fuel make sure fuel line from tanks not restricted first before condeming the fuel pump
Fuel pump would be next other than checking fuel shut of solenoid on bottom of carburetor for it blocks of main jet in carb
Good Luck
